San Jose
2025 Taycan GTS
I guess this is new... with not much new information: https://newsroom.porsche.com/en/202...l-electric-718-boxster-development-43799.html
I don't think we've seen this before:
Enhanced driving pleasure at the touch of a button
All 718 Boxster models will be equipped with E-Shift as standard. At the touch of a button, a virtual seven-speed PDK transmission can be activated, bringing the defining characteristics of the PDK driving experience into the world of electric propulsion. The virtual gear shift characteristics vary depending on the selected driving mode. Just like with a real PDK system, the driver can choose between automatic gear changes or manual shifts using the paddles behind the steering wheel. Thanks to a targeted increase in torque during the shifting process, performance is identical whether E-Shift mode is activated or deactivated. In E-Shift mode, the virtual shifting experience is accompanied by the faithfully recreated sound of a six-cylinder boxer engine, based on the distinctive sound of the 981-generation Boxster GTS. When E-Shift mode is not active, the paddles take on a different function: instead of virtual gear changes, they can be used to select between three stages of recuperation.
babylou66
Houston
Boxster GTS 4.0, Cayenne S EV
What Car says same weight as recently retired GTS so ~1450 kg (3200 lb). That'll do just fine!
Porschephile13
United States
A6 e-tron
Gasser was 1.5 tons, so pretty much the same. Length is the same. width is the same. They've essentially taken out the engine and put in a battery, while keeping the dimensions the same. congratulations, Porsche! If this had been a rush job and had fallen short, you'd have been crucified.
San Jose
2025 Taycan GTS
As long as it's close to 300 mile range, though I suspect it's going to be in low 200s.
refazi
Refael
San Francisco, CA
2022 Taycan RWD, 2021 Taycan 4S
So from what i gathered so far -
Gas sounds
e-shift standard "7 speed PDK"
RWD only
Rear wheel steering
low and high power versions (I guess base and S)
Not revealed - power, range, top speed, battery, weight..
Gas sounds
e-shift standard
RWD only
Rear wheel steering
You can add:
2 boxter trims confirmed so far; only RWD, no AWD trim. So would assume Boxter EV and Boxter S EV?
0-62mph in less then 3 seconds
911 992.2 steering & brakes.
The sound is from a cayman gts.
adaptive dampers, so PASM, no active ride for the Boxter EV.
I was expecting a lot more specs to be revealed to be honest.
Weight we know from the slip up of the porsche test driver in the "first drive" event to be 1700kg.
One of the reviewers also say: similar weight to 911 (the gts); so preatty much confirmed at 1700kg.
Porschephile13
United States
A6 e-tron
You can add:
I thought one of the reviewers (Edmunds, I think) said the demo cars were all AWD.
