[US] - Over the Top - the well equipped EV home garage…for those that wish to "over do it"…
What do I tick in the poll?
You click Level Beyond or Level 6 (since you're doing 11 kW) - the write up doesn't apply to Europe since I don't know squat about power in Europe.
evanevery
Ed
Wisconsin
2020 Taycan Turbo S, 2019 BMW i8, 2023 BMW iXM60
I have THREE EV's currently charging in my garage using TWO dedicated 50A circuits:
1. My Tesla Model X has a dedicated 50A circuit for a hardwired Tesla Wall Charger
2. My Taycan Turbo S also has a dedicated 50A circuit which terminates in a Nema 14-50 socket. I have a 40A Mustek Level 2 charger plugged in here but can be unplugged so I can use the same outlet for my Welder or CNC Plasma Cutter/Router.
3. My BMW i8 Roadster simply uses a charger plugged into a standard 15A/120V outlet as its battery capacity (11.6 KWH) doesn't really justify anything larger. (...and, as a plug-in Hybrid, doesn't really REQUIRE a battery charge to operate at all)
HK111
Henrik
Germany
Taycan GTS, Corvette C7 Stingray, Mercedes V
That is pretty good. In the future, I'd also like to be able to charge two cars in parallel. But this will have to wait: I don't know of a 6-person-family EV except maybe Tesla, but don't like their design. Plus, it would have to be the size of a V-class. I hope that the VW bus will be worth the wait.
evanevery
Ed
Wisconsin
We were going to sell the Model-X when we got the Taycan, but my wife still prefers it as a daily driver. It really is much more capable in some ways.
seeing the charging experience for the Taycan - my wife has banned it from being our road-trip car - and we're keeping the Model X for road trips - all she had to see was the one time she was with me and we couldn't unplug the cable with the Taycan and she was convinced Tesla's got a lead for bit…
LukeManning
Luke
Grapevine, TX
Website
www.porschegrapevine.com
Work at Porsche Grapevine as the Taycan specialist.
There are several levels of preparing your garage for your future EV baby (babies)…since all EV's can charge from just about any amount of electricity one can pretty much charge from any garage that has electrical power if one has the time…
Read below for what level you are - level 5 is the recommendation for most people - level's beyond 5 require a certain madness and willingness to engage in the un-necessary but potentially beneficial future planning.
Go on take the EV charging home setup test - what level are you?
Level 0 - Public Charging - no charging for me in my garage - that's the wimps way out!!
You are all wimps - OMG you have to have a charger installed in your home and your garage to be a security blanket for your EV ownership. Grow a pair, embrace the future, and rely solely on public EV charging infrastructure. Me - I"m going to charge at 270 kW ALWAYS - because it's fast, it's free - and I'm developing a relationship with this one gal on the EA customer support line, she sounds nice, and always comp's me my charging session…do you think I should ask her out?​
And beside I can shop at Whole Foods while my car charges in the parking lot - win win!!​
Level 1 - Inadequate but some people try - NEMA 5-15 Household Outlet - 1.44 kW - 120 volts @ 15 amps (12 amps for charging)
(70 hours for a full charge from near zero % battery).​
this can be done, and for 8-10 hours over night you can add 12-14 kWh - which is about 50 miles daily driving range - I don't recommend it -but technically it works and most garages have an existing NEMA 5-15 so this is the zero cost I'm going to use what I have approach. In North America the PMCC comes with this plug adapter so it will all just work - but be painful slow for any serious charging demands​
Level 2 - Slight better but still Inadequate - NEMA 5-20 - 1.92 kWh - 120 volts @ 20 amps (16 amps for charging)
(50 hours for a full charge from near zero % battery).
not much better than the NEMA 5-15 but is technically faster - 8-10 hours charging is almost 20 kWh - or about 65 miles daily driving range - again many people might have this already in their garage for an engine block heater or air compressor​
the PMCC does not come with a NEMA 5-20 adapter, and Porsche doesn't sell one - you'd have to buy an EVSE that offers this support - and by the time you're buying another EVSE - why oh why would you stop here? It's documented purely for completeness.​
Level 3 - I own an RV and have a NEMA TT-30 installed near my drive way - I can just use that!!! 2.88 kW - 120 volts @ 30 amps (24 amps for charging)
(34 hours for a full charge from near zero % battery).​
RV hooks up come in two flavors - NEMA 14-50, and NEMA TT-30s - it's therefore likely some people will already have this in their garage, side of the house, or near the driveway for their RV -this isn't a half bad circuit - 2.88 kW can do nearly 30 kWh over night - which is almost 100 miles daily driving for your typical 10 hour overnight charging session.​
Porsche doesn't sell a TT-30 adapter, so you'd have to buy a TT-30 to NEMA 10-30, 6-30, 14-30 adapter and then use a 30 amp EVSE with this setup (the PMCC with one of Porsche's 30 amp supply cables would do the trick) - it will work and may not be horrible - still a bit of a jury rig IMHO and still not ideal for occasional high usage days - but fine for daily driving.​
Level 4 - I have an unused 30 amp circuit in/near my garage - NEMA 6-30, 10-30, 14-30 plug 5.76 kW - 240 volts @ 30 amps (24 amps for charging)
(16 hours for a full charge from near zero % battery)​
this is the bare minimum for an EV owner in my humble opinion but honestly will do just fine for most usage. The only issue with this approach is the plug is unlikely to be well located relative to where you'd want it for EV charging and EVSE placement - still it's better than nothing and will offer a healthy 57 kWh for a 10 hour overnight charge or almost 200 miles daily driving range for a 10 hour charge session.​
Porsche sells a NEMA 6-30 or 14-30 adapter for the PMCC that comes with the car, and your electrician bill is likely to be cheap to change/move the plug. This is a great choice and if you already have one of these in the garage it certainly is going to be the cheapest option for getting your EV charging up and going.​
Also a viable option if your electrician says your home can't handle the addition of a 50 amp circuit without a main panel upgrade (expensive o_O:crying::headbang::() - you might be able to get away with a 30 amp breaker - for less $$$​
Level 4.5 - I have an existing 40 amp 7.2 k2 (32 amp) EVSE from previous EV ownership and see no reason to upgrade
(13 hours for a full charge from near zero % battery)​
this is a great choice - and honestly if you've already got a 40 amp (32 amp) EVSE installed this will charge your Taycan just fine and reasonably fast. I honestly can't fault anyone for this approach.​
Level 5 - I have or I'm going to install a 50 amp circuit + plug - NEMA 6-50 or NEMA 14-50 - 9.6 kW - 240 volts @ 50 amps (40 amps for charging)
(11 hours from a full charge from near zero % battery)​
this is the recommend path from me and Porsche and the EV community at large - this will exploit the full power of the included Porsche Mobile Charge connect and is the largest circuit one can have installed with a mobile EVSE. NEMA 14-50 can provide a healthy 96 kWh in 10 hours of charging, which is more than the capacity of your Taycan's battery. Daily drives of up to 80 miles a day will be dispatched over night in less than 3 hours of charging time on one of these circuits. This circuit matches the Porsche North American specification for maximum charge rate and is an excellent all around choice.​
There is nothing wrong with this install and it will nearly maximize your Taycan's charging rate and for 98% of your lifetime usage it will never take more than 4 hours to charge your vehicle - this is affordable, easy, and will serve you well over the next several years.​
Normal people stop here - do not proceed unless you want your mind blown!!! If you are timid, logical, and only interested is what is necessary and prudent, and well considered - please do not proceed beyond this point. What lies beyond this point in the posting is pure madness and only for those that wish to over prepare!!​
:devil::handsinair::computerrage::muscle::headbang:​
Level 6 - I read Internet forums and I know Porsche is lowballing us with the 9.6 kW specification - my Taycan can actually charge at 11 kW - 240 volts @ 60 amps (48 amps for charging)
(8.5 hours for a full charge from near zero % battery)​
it turns out the maximum charge rate for your Taycan is not 9.6 kW, but in fact 11 kW like the rest of the world. However to realize that charge rate you'll have to install a non-Porsche EVSE (no problem 100% confidence in this approach - honestly no big deal) - but the charger will NOT be mobile, it will be hardwired.​
However to realize this you need to have a 60 amp circuit installed and purchase sometime like a Tesla Wall Charger Gen2 or ClipperCreek HCS60 EVSE - this will charge your Taycan at it's true maximum charge rate of 11 kW - meaning in 4 hours of charging you can pump 44 kWh of raw unbridled power into your battery - leading to a driving range of just over 140 miles range. Your wimp-ass daily roundtrip commute of 52 miles will take a mere 100 minutes of charge time - I laugh at your charge time and think you are too much of a pretty boy to have it this good!!!​
Level - ∞ @daveo4EV - how can I do more? I wish to prepare for today and tomorrow and really really want the ideal setup for my garage!!! I not only want to prepare my garage for my Taycan but I want to over prepare my garage for all future EV power options - 11 kW is good, but how can I do more? How can I prepare my garage for today, tomorrow and my eventual needs as a 1st world consumer that wants for nothing!!! I'm the type of person that must over prepare and be ready for anything!!!
Well my friends you've come to the right place :cool:. There are steps you can take to make your current EV charging scenario maximize your Taycan charging experience, but also prepare you for your glorious multi-EV future.​
  • Buy an EV with more than 11 kW charging capacity - yeah we've got you covered!
  • Need charging for multiple EV's simultaneously - yeah no problem!
  • Want to have both plug based and hardwire options for maximum ease of use and EV kingdom control - yeah this is the setup for you!
Drum roll please, :rock:this is @daveo4EV ideal over the top totally un-necessary EV garage setup plan for today, tomorrow and the future:​
  • Add a 125 amp circuit to your existing main house panel
    • Route this 125 amp circuit to a brand new 8+ slot 150 amp sub-panel installed in your garage
    • Install a 100 amp breaker as the main breaker in this new subpanel (double breakers for maximum safety, 125 amps at the main, 100 amps on the sub)
  • Install an 80 amp breaker in the new subpanel
    • off of this new shiny 80 amp breaker - install a ClipperCreek HCS80 share2 EVSE (64 amps of charging goodness for your Taycan and future EVs)
      • NOTE: this will not charge your Taycan any faster than the HCS60 - but will potentially charge future EV's faster if they can handle the raw power
  • Also Install a 50 amp breaker in the new subpanel
    • off of this new shiny 50 amp breaker - install a NEMA 6-50/14-50 plug for maximum easy of use, and flexibility. This plug will be there incase your EVSE is broken (wife has run over the cable and broken your plug) or just testing EV equipment for which you need a NEMA 14-50/6-50 plug handy
A nice juicy 125 amp dedicated circuit to your garage will allow for future dual 60 amp EV chargers to charge 2 EV's at 48 amp each!!! And the addition of a NEMA 14-50 for the pure convenience of having a 14-50 plug handy means that you can test, and play with various EV chargers with a minimal hassle factor. Yes my friends this is how you over do an EV charging setup. 60/80 amp EVSE from Clipper Creek & NEMA 14-50 plug for all your other EV testing/charging needs. All wrapped up in a nice tidy 100 amp sub-panel in the garage so that it's easy to change and play with your EV charging configurations to remain over the top and flexible far into the future.​
This is an awesome guide. Thank you for this.
MN_taycan
Scott
Minnesota, USA
2020 Taycan Turbo S, 2018 Audi S7, 1972 Datsun 240Z
Happy coincidence that we had just ripped out a hot tub at the house, so had a free 50A circuit out of 400A service. Ran that to garage and put in the 240V NEMA 14-50 outlet for the mobile charger connect. Same setup at autoplex (where the car spends some of it's time). Have one of the absurdly expensive housings for the mobile charger connect shipping from Suncoast this week - but I suppose if I'm posting on this forum I can't really complain about overpaying for stuff.
redrocket
Joe
USA
Taycan Turbo, Panamera 4S, Bimmer X3
Daveo, why would you need a Gen 2 Tesla charger, wouldn't a Tesla Gen 3 work as well? thanks
you are correct a Gen1, Gen2, Gen3 Tesla Wall Charger "should" work - I only have personal experience with the Gen2 wall chargers (and some Gen1 but those don't count)…
Gen3 is interesting - it communicates for loadsharing via WiFi, and has a 60/48 amp limit - the Gen2 is 20-100 amps and uses two wire daisy chain for 1 master and up to 3 slaves…
Gen3 should work fine, but I have not yet personally tested or played with a Gen3 Tesla Wall Charger…my apologies for being unclear on that - if anyone gets a Gen3 Tesla Wall Charger it would be interesting to hear their experiences
it is with some sadness that I note the Tesla site no longer offers the Gen2 Tesla Wall charger for sale via their website - it was perhaps the best and certainly most affordable 100/80 amp charger on the EVSE market.
they are currently offering their Gen3 model - I have no personal experience with Gen3 and therefore have no opinion on it (good or bad).
ClipperCreek makes solid 60/80/100 amp chargers - their Share2 feature is great for future multi-EV households and allows 2 clipperCreek chargers to share one circuit/breaker.
the Tesla Gen2 wall charger for $500 was an awesome deal - it's a pity this is no longer an option.
redrocket
Joe
USA
posting updated - thanks @redrocket
Actually I a have a Gen 2 I can use. Think I’ll relocate it this weekend for use with the taycan. Wire size I have is good, so I’d get a higher charging rate without the heat issue as from the Porsche unit. The Porsche unit will be stuffed in a bag for use on trips. Kinda pissed I spent so much dinero on that charger w/wall box.
make sure you're using an 80 amp TeslaTap/JDapter - the 40 amp version's may overheat when used at the full 48 amp charge rate the Taycan can support.
redrocket
Joe
USA
Ok, so I ordered a Tesla Gen 3 charger, hooked it up, and am using a 40 amp teslatap....couldn’t find the 80 amp version. Works like a champ, and nothing in the system is warmer than lukewarm. Charger takes up minimal space and at $500 is a steal. The Porsche charger and cabinet is a POS in comparison.
updated original post - new level - level 7 - for those that are powerful enough to order the optional 19,200 watt North American charging option!!!
